StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
Quicklinx: 67CQWS00 Mfr#: PEX4S952
Type: Serial adapter
Compatibility: Mac, PC
Interface: PCI Express x1
31 in stock
£65.28 ex VAT
£78.33 inc VAT
Add four RS232 serial ports to any PC using a single PCI Express expansion slot. The PEX4S952 4 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART allows you to turn a PCI Express slot into 4 RS-232 (DB9) serial connections.
The four port serial card is based on a native single chip design, that harnesses the full capability of PCI Express (PCIe) - providing optimum reliability and speed, and reducing the load applied to the CPU by as much as 48% over conventional serial cards.
Offering compatibility with a broad range of operating systems including Windows, Linux and Mac OS for easy integration into mixed environments. Plus, an included optional low profile/half-height bracket that allows the card to be installed in virtually any computer case - making it that much easier to add serial ports to your PCI Express enabled computer, regardless of the case form factor.
StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
RS-232 x 4
2 cm x 9 cm x 6.5 cm
58 g
RS-232
Microsoft Windows 2000 / XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows 2003, Windows 10 (32/64 bits)
Serial adapter
Plug-in card
PCI Express x1
Ports
RS-232 x 4
Wired
RS-232
Software flow control, hardware flow control
4 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
FCC, RoHS
2 cm
9 cm
6.5 cm
58 g
Limited warranty - lifetime
67CQ StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
67CQ StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
67CQ StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
67CQ StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
67CQ StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
67CQ StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 50 - 100
