Add 4 high-speed RS-232 serial ports to your PC through a low profile PCI Express expansion slot. The PEX4S952LP 4 Port Low Profile Native RS232 PCI Express Serial Card (16950 UART) turns a PCI Express slot into four RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, and ships with a half-height/low profile bracket installed, but also includes an optional full profile bracket that lets you add four serial ports to virtually any computer (regardless of the case form factor).
- StarTech.com Replaced by PEX4S953LP - 4 Port Low Profile Native RS232 PCI Express Serial Card (PEX4S952LP) - serial adapter - PCIe - RS-232 x 4
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0a
- Ports
- RS-232 x 4
- 2 cm x 9 cm x 8 cm
- 58 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460.8 Kbps
- Processor
- 1 x Oxford Semiconductor OXPCIe954
- System Requirements
- Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Vista / 2000 / XP
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI Express x1
- PCIe 1.0a
- Ports
- RS-232 x 4
- Connectivity Technology
- Wired
- RS-232
- 460.8 Kbps
- Software flow control
Processor / Memory
- Processor
- 4 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
- Compatible Slots
- 1 x PCI Express x1
- WHQL, FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 2 cm
- 9 cm
- 8 cm
- 58 g
- Limited warranty - lifetime
- -20 °C
- 85 °C
- 5 - 85%
