StarTech.com 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART
Quicklinx: 6PGFWS00 Mfr#: PEX4S952LP
Type: Serial adapter
Compatibility: PC, Unix
Interface: PCI Express x1
11 in stock
£65.28 ex VAT
£78.33 inc VAT
Add 4 high-speed RS-232 serial ports to your PC through a low profile PCI Express expansion slot. The PEX4S952LP 4 Port Low Profile Native RS232 PCI Express Serial Card (16950 UART) turns a PCI Express slot into four RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, and ships with a half-height/low profile bracket installed, but also includes an optional full profile bracket that lets you add four serial ports to virtually any computer (regardless of the case form factor).
StarTech.com 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
RS-232 x 4
2 cm x 9 cm x 8 cm
58 g
RS-232
Data Transfer Rate
460.8 Kbps
1 x OXPCIe954 - Oxford Semiconductor
Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Vista / 2000 / XP
Serial adapter
PCI Express x1
PCIe 1.0a
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
460.8 Kbps
Software flow control
Processor / Memory
4 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
Compatible Slots
1 x PCI Express x1
WHQL, FCC, RoHS
Software Included
Drivers & Utilities
2 cm
9 cm
8 cm
58 g
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
6PGF StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
6PGF StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
6PGF StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
6PGF StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
6PGF StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
6PGF StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 50 - 100
