StarTech.com 4 Port Industrial RS-232 / 422 / 485 Serial to IP Ethernet Device Server
Quicklinx: 98FSWS00 Mfr#: NETRS42348PD
Type: Misc
£350.00 ex VAT
£420.00 inc VAT
Remotely manage 4 industrial RS232 or RS422/485 serial device over an IP network, with redundant 10/100 Ethernet ports. The PoE-powered NETRS42348PD 4-Port Industrial Serial Device Server lets you remotely manage up to four industrial RS232/422/485 serial devices over a local or wide area network (LAN/WAN), with redundant power inputs and dual 10/100Mbps Ethernet ports.
To minimize downtime, this intuitive dual Ethernet serial over IP solution maintains connection to your critical equipment by automatically switching to its secondary LAN port within 10 milliseconds of a network failure or disruption.
Ideal for industrial environments, the serial to Ethernet device server accepts wide-range 12-48V DC power input via a terminal block, or through a PoE RJ45 port. Redundant power inputs keep the device server functional in the event of power surges or failures, and when used with a PoE-capable switch or injector, the serial device server can be conveniently installed in locations where terminal block power is unavailable.
This device server supports baud rates up to 460.8Kbps which provides a smooth, high-speed connection to your serial devices. The device server also offers support for HTTPS, SSH and SSL to ensure secure communication, while integrating remote Telnet configuration and support for IP, HTTP, ICMP, DHCP, ARP, TCP and UDP protocols. You can customize the serial device server to suit your application with versatile browser-based or virtual com port software configuration.
Ensuring performance in harsh environments, this serial device server offers 8KV air, and 4KV contact ESD (Electrostatic Discharge) protection and features a rugged, IP-30 case design that is both DIN rail and wall-mountable.
StarTech.com 4 Port Industrial RS-232/422/485 Serial PoE IP Device Server - device server
Device server
External
Ports Qty
4
Ethernet, Fast Ethernet, RS-232, RS-422, RS-485
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019
Power Over Ethernet (PoE) Supported
PoE
10.6 cm x 5.2 cm x 14.4 cm
0.7 kg
5-year warranty
Device server
10.6 cm
5.2 cm
14.4 cm
0.7 kg
Enclosure Colour
External
Ports Qty
4
Wired
Data Transfer Rate
460.8 Kbps
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, PPPoE, SMTP, BOOTP, DHCP, DNS, DDNS
Remote Management Protocol
SNMP 1, SNMP 2c, SSH
Status Indicators
Port status, power, fail, PoE
Flow control, auto-uplink (auto MDI/MDI-X)
Encryption Algorithm
128-bit SSL
Authentication Method
Secure Shell (SSH)
IEEE 802.3, IEEE 802.3u, IEEE 802.3af
4 x RS-232/422/485 - DB-9 , 2 x 100Base-TX - RJ-45
MTBF
569,972 hour(s)
FCC, RoHS
PoE
Software Included
Drivers & Utilities
Limited warranty - 5 years
-10 °C
70 °C
5 - 95% (non-condensing)
98FS StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.85
98FS StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
98FS StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.49
98FS StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £3.88
98FS StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
98FS StarTech.com 4 Port Industrial RS-232 / 422 / 485 Serial to IP Ethernet Device Server In Stock £350.00
Type: Misc
Price Range Ex VAT: 300 - 500
