The StarTech.com VideoView Pro is a High-End 4 port VGA Video Splitter that allows a PC to display to as many as 4 monitors simultaneously. It is perfect for presentations, classrooms, tradeshows, or in-store displays where the highest quality video on several monitors is needed. The VideoView Pro supports monitors with up to 350MHz of bandwidth allowing it to display images of 2048 x 1536 pixels or higher. A built-in booster circuit allows the video signal to be extended up to 200 ft.
- StarTech.com 4 Port High Resolution VGA Video Splitter - 350 MHz - video splitter - 4 ports
- Video splitter - 4 ports
- Subtype
- VGA
- Ports
- 4 x VGA
- Power
- AC 230V
- 22.4 cm x 15.2 cm x 5.2 cm
- 1.2 kg
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- VGA
- Ports
- 4 x VGA
- Max Resolution
- 2048 x 1536 @ 80 Hz
- Max Video Bandwidth
- 350 MHz
- Status Indicators
- Power, active
- 4 x VGA HD-15 , 1 x VGA HD-15
- Power Device
- External power adapter
- Voltage Required
- AC 230V
- Black
- FCC Part 15
- 22.4 cm
- 15.2 cm
- 5.2 cm
- 1.2 kg
- Limited warranty - 2 years
