Your basket is empty
StarTech.com 4 Port High Resolution VGA Video Splitter - 350 MHz
Quicklinx: 9CQDWS00 Mfr#: ST124PROGB
The StarTech.com VideoView Pro is a High-End 4 port VGA Video Splitter that allows a PC to display to as many as 4 monitors simultaneously. It is perfect for presentations, classrooms, tradeshows, or in-store displays where the highest quality video on several monitors is needed. The VideoView Pro supports monitors with up to 350MHz of bandwidth allowing it to display images of 2048 x 1536 pixels or higher. A built-in booster circuit allows the video signal to be extended up to 200 ft.
StarTech.com 4 Port High Resolution VGA Video Splitter - 350 MHz - video splitter - 4 ports
Video splitter - 4 ports
Subtype
VGA
Ports
4 x VGA
AC 230V
22.4 cm x 15.2 cm x 5.2 cm
1.2 kg
2 years warranty
Enclosure Type
Desktop
Subtype
VGA
Ports
4 x VGA
Max Resolution
2048 x 1536 @ 80 Hz
Max Video Bandwidth
350 MHz
Status Indicators
Power, active
4 x VGA HD-15 , 1 x VGA HD-15
External power adapter
AC 230V
FCC Part 15
22.4 cm
15.2 cm
5.2 cm
1.2 kg
9CQD StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £13.70
9CQD StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.73
9CQD StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £9.91
