StarTech.com 4-Port HDMI video switch – 4K
Quicklinx: B14FWS00 Mfr#: VS421HD4K
Switch between four HDMI sources on a single HDMI display, with support for MHL and video resolutions up to 4K. The VS421HD4K 4-port HDMI 4K switch lets you share a display or projector with four HDMI-enabled audio / video source devices. The switch features four independent inputs that each support 4K resolution and 7.1 surround sound audio.
The 4-port switch also features MHL support on HDMI input port 1, enabling video output video from MHL-enabled mobile devices such as Samsung Galaxy tablets and smartphones.
You'll be amazed at how this video switch maintains Ultra HD picture quality. 4K is supported by the latest A/V devices and delivers four times the resolution of 1080p. Plus, because the switch is backward compatible with high-definition 1080p, you can rest assured any video source will look great in your digital signage application.
Constructed of solid aluminum, the HDMI switch is durable and heavy enough to prevent the unit from lifting or sliding around if the attached HDMI cables are bumped or shifted. Plus, its small footprint makes it easy to integrate the switch into any boardroom, classroom, home theater, or digital signage application.
This switch ensures effortless operation with automatic switching that detects and selects a newly connected device. Automatic switching encourages on-the-fly collaboration among colleagues, by making it easy to share your projector between multiple source devices in a boardroom or classroom environment. The VS421HD4K also supports manual operation using the included IR remote control, or the built-in front panel toggle switch directly on the device.
StarTech.com 4 Port HDMI Switch - 4K 30Hz - Aluminum Housing and MHL Support - 4x1 HDMI Switcher Box - 4K HDMI Selector Switch with Remote (VS421HD4K) - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
Ports
4 x HDMI
7.1 channel audio support
AC 100/230 V
13.9 cm x 8.5 cm x 1.4 cm
285 g
North America, United Kingdom, Europe
P/N: SVA5M3NEUA
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
Max Resolution
3840 x 2160
Status Indicators
Port status, power
1 x HDMI output , 4 x HDMI input
External power adapter
AC 100/230 V
Remote control, IR extender
FCC, RoHS
13.9 cm
8.5 cm
1.4 cm
285 g
70 °C
5 - 90%
Min Storage Temperature
-10 °C
Max Storage Temperature
80 °C
P/N: SVA5M3NEUA
B14F StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.28
B14F StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
B14F StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.92
B14F StarTech.com DC Power Adapter - 5V, 3A In Stock £11.75
B14F StarTech.com 4-Port 4K HDMI Video Switch In Stock £146.05
B14F StarTech.com 2-Port 4K HDMI Video Switch In Stock £99.96
B14F StarTech.com 2x2 HDMI Matrix Switch - 4K In Stock £146.56
B14F StarTech.com 4-Port HDMI Switch - 4K In Stock £39.96
B14F StarTech.com 2-Port HDMI Switch - 4K In Stock £32.85
B14F StarTech.com DC Power Adapter - 5V, 2A In Stock £10.25
