StarTech.com 4-Port HDMI Switch with Picture-and-Picture Multiviewer
Quicklinx: 9TVFWS00 Mfr#: VS421HDPIP
Type: Video splitter
Connectivity: HDMI
Ports: 4
Hurry, only 2 left in stock!
£869.81 ex VAT
£1,043.77 inc VAT
Share an HDMI display between four distinct HDMI audio/video sources, with optional Picture-and-Picture. The VS421HDPIP 4-Port HDMI Video Switch with Picture-and-Picture (PAP) lets you connect four HDMI video sources to a single HDMI display with the added benefit of playing all four video sources on your display simultaneously with combined video.
The split-screen multiplexing switch gives you the flexibility of a 4-port video switch with the added benefit of combining two, three or four video sources onto your output display. The switch supports three different picture-and-picture modes per display: Matrix Mode (1x1) / Dual Mode (2x1) / Quad Mode (4x1).
Fitting your boardroom or digital signage application with a VS421HDPIP dramatically increases your communication possibilities. Not only does the picture-and-picture switch increase your communication by a factor of four, but it also enables you to adjust your video sources remotely using RS232 serial, your local TCP/IP network, or the included IR remote control.
The VS421HDPIP is a flexible video switch that can improve any video display application. The picture-and-picture technology enables you to share up to four distinct images on the same screen, reducing required video real estate and saving you from wasting money on additional displays in a digital signage applications. For security monitoring you can combine four video sources across a single display to view everything more efficiently - you can even zoom into a single feed for a closer look. For versatile installation options mounting hardware is also included ensuring a tidy professional installation.
StarTech.com 4-Port HDMI Switch with PIP - video splitter - 4 ports
Video splitter - 4 ports
Subtype
HDMI
Ports
4 x HDMI
AC 120/230 V
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
4 x HDMI
External power adapter
AC 120/230 V
FCC, RoHS
9TVF StarTech.com 4-to-1 HDMI Video Switch with Remote Control In Stock £46.75
9TVF StarTech.com 4x4 HDMI Matrix Video Switch Splitter with Audio and RS232 In Stock £446.89
9TVF StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.57
9TVF StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.14
9TVF StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £13.48
9TVF StarTech.com 4x4 HDMI Matrix Switcher / HDMI Extender over Cat5 / Cat6 – 230ft (70m) – 1080p In Stock £1,092.48
9TVF StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p In Stock £95.40
9TVF StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall In Stock £1,077.36
9TVF StarTech.com 4-Port HDMI Switch with Picture-and-Picture Multiviewer In Stock £869.81
Connectivity: HDMI
Ports: 4
Price Range Ex VAT: 750 - 1000
