StarTech.com 4 Port HDMI KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable
Quicklinx: C5SKWS00 Mfr#: SV431HDU3A2
Type: KVM / USB switch
Connectivity: KVM
Ports: 4
15 in stock
£268.52 ex VAT
£322.22 inc VAT
Control four HDMI computers using a single console, with a built-in USB 3.0 hub for sharing additional peripheral devices. This 4-Port USB 3.0 HDMI KVM switch lets you control four HDMI computers with a single monitor, keyboard and mouse. The KVM also features 3.5 mm audio and a built-in 3-port USB 3.0 hub.
This KVM switch offers a built-in 3-port USB 3.0 hub that's separate from your HID keyboard and mouse, so you can share USB peripheral devices between each connected computer and avoid the expense of separate equipment. The USB 3.0 hub automatically switches your connected USB devices to the selected computer, saving you the hassle of disconnecting and reconnecting peripherals.
With support for USB 3.0, you can achieve data transfer rates up to 5Gbps, to ensure flawless performance for your USB peripherals - great for quickly transferring data to external USB 3.0 drives.
Offering support for high-definition 1080p resolutions, this 4-port HDMI KVM switch has the ability to drive HDMI displays with crystal clarity, making it ideal for graphical applications that require 1920 x 1080 video resolutions.
The KVM switch features auxiliary 3.5 mm audio ports that enable you to share independent analog audio, from each of your connected computers, with your desktop speaker set. Independent audio, along with 1080p HDMI video, gives you full multimedia control between different computers, making this KVM perfect for creative professional applications such as video and sound design or editing.
StarTech.com 4 Port HDMI KVM - HDMI KVM Switch - 1080p - USB 3.0 & Audio Support - KVM Video Switch (SV431HDU3A2) - KVM / USB switch - 4 ports - rack-mountable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
4 x KVM / audio / USB + 3 x SuperSpeed USB
KVM Users Qty
1 local user
Built-in 3-port SuperSpeed USB 3.0 hub
AC 120/230 V / DC 9 - 12 V
Australia, North America, United Kingdom, Europe
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1080 @ 60 Hz
Status Indicators
Power, select
1 x HDMI output , 4 x USB output Type A , 1 x audio output mini-jack , 4 x HDMI input , 4 x USB 3.0 input Type B , 4 x audio input mini-jack , 3 x USB 3.0 Type A
Internal power supply
4 rubber feet
FCC, RoHS, WEEE
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
C5SK StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £301.19
Connectivity: KVM
Ports: 4
Price Range Ex VAT: 150 - 300
