StarTech.com 4 Port DVI Video Splitter with Audio
Quicklinx: 76Q6WS00 Mfr#: ST124DVIA
Type: DVI Splitter
£151.69 ex VAT
£182.02 inc VAT
The ST124DVIA DVI splitter lets you share one DVI video and audio source on four displays and acts as a signal amplifier that allows you to locate your DVI monitors up to 33ft (10 m) away from your computer or DVI signal source.
With support for high definition resolutions up to 1080p (HDTV)/1920x1200 (PC), the DVI splitter delivers a simple and convenient DVI video solution that suits virtually any application or operating environment (classroom, healthcare, professional A/V, control centers, retail POS environments).
The DVI video splitter/distribution amplifier is easy to install, providing you with flawless digital video that will help you get the most from your DVI-enabled monitors, projectors, or plasma screens. The DVI splitter/signal distribution amplifier is designed to provide dependable performance.
StarTech.com 4 Port DVI Video Splitter with Audio - video/audio splitter - 4 ports
Video/audio splitter - 4 ports
Subtype
DVI / audio
Ports
4 x DVI + 4 x audio
HDCP 1.1, DVI 1.0
13.5 cm x 22 cm x 4.4 cm
1.1 kg
Enclosure Type
Desktop
Subtype
DVI / audio
Ports
4 x DVI + 4 x audio
Max Resolution
1920 x 1200 @ 60 Hz
HDCP 1.1, DVI 1.0
4 x DVI-I , 4 x audio mini-jack , 1 x DVI-I , 1 x audio mini-jack
External power adapter
FCC, RoHS
13.5 cm
22 cm
4.4 cm
1.1 kg
0 - 80%
76Q6 StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.77
76Q6 StarTech.com 20 ft DVI-D Single Link Cable - M/M In Stock £18.57
76Q6 StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.55
76Q6 StarTech.com 6 ft DVI-D Single Link Monitor Extension Cable - M/F In Stock £9.32
76Q6 StarTech.com 10 ft DVI-D Single Link Monitor Extension Cable - M/F In Stock £12.75
76Q6 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.42
76Q6 StarTech.com 15 ft DVI-D Single Link Monitor Extension Cable - M/F In Stock £14.43
76Q6 StarTech.com 10 ft HDMI to DVI-D Cable - M/M In Stock £8.58
76Q6 StarTech.com 4 Port DVI Video Splitter with Audio In Stock £151.69
76Q6 StarTech.com 2 Port DVI Video Splitter with Audio In Stock £80.71
76Q6 StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.89
Type: DVI Splitter
Price Range Ex VAT: 150 - 300
