StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub
Quicklinx: 6LCZWS00 Mfr#: SV431DDVDUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
More than 50 in stock
£198.78 ex VAT
£238.53 inc VAT
The SV431DDVDUA 4-port DVI VGA dual monitor KVM switch lets you control 4 Dual Display computers using a single USB mouse and keyboard peripheral set.
This dual view KVM switch provides 1 VGA and 1 DVI-I port per computer connection for high-resolution video, as well as audio switching capability between connected computers.
The DVI/VGA KVM switch features an integrated 2-port USB hub that allows USB 2.0 peripherals to be shared between connected computers, and offers a compact design with a rugged metal chassis for durable performance.
While both DVI-I (analog) and DVI-D (digital) are supported by the KVM, source PCs must output the same signal for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com StarView 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
22 cm x 13 cm x 6 cm
1.2 kg
3-year warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
1 x VGA HD-15 , 1 x DVI-D , 4 x USB 2.0 Type A , 2 x audio mini-jack , 4 x VGA HD-15 , 4 x DVI-D , 4 x audio mini-jack , 4 x USB 2.0 Type B
External power adapter
FCC, RoHS
22 cm
13 cm
6 cm
1.2 kg
Limited warranty - 3 years
6LCZ StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
6LCZ StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.90
6LCZ StarTech.com 6 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £14.08
6LCZ StarTech.com 10 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £18.53
6LCZ StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £255.16
6LCZ StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £198.78
6LCZ StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £18.78
6LCZ StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
6LCZ StarTech.com USB DVI KVM Cable In Stock £18.53
6LCZ StarTech.com 10 ft 4-in-1 USB VGA KVM Cable with Audio and Microphone In Stock £16.16
6LCZ StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £107.19
6LCZ StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £159.68
6LCZ StarTech.com 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone In Stock £11.71
6LCZ StarTech.com 2 Port USB DVI KVM Switch with DDM Fast Switching Technology and Cables In Stock £160.38
Connectivity: KVM
Ports: 4
Price Range Ex VAT: 150 - 300
