StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub
Quicklinx: 6LCZWS00 Mfr#: SV431DDVDUA
Type: KVM / audio / USB switch
Ports: 4
Connectivity: KVM
Hurry, only 1 left in stock!
£277.79 ex VAT
£333.34 inc VAT
The SV431DDVDUA 4-port DVI VGA dual monitor KVM switch lets you control 4 Dual Display computers using a single USB mouse and keyboard peripheral set.
This dual view KVM switch provides 1 VGA and 1 DVI-I port per computer connection for high-resolution video, as well as audio switching capability between connected computers.
The DVI/VGA KVM switch features an integrated 2-port USB hub that allows USB 2.0 peripherals to be shared between connected computers, and offers a compact design with a rugged metal chassis for durable performance.
While both DVI-I (analog) and DVI-D (digital) are supported by the KVM, source PCs must output the same signal for proper switching. It is recommended wherever possible to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio and USB 2.0 Hub (SV431DDVDUA) - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub, HDCP compliant
22 cm x 13 cm x 6 cm
1.2 kg
3-year warranty
P/N: IM12D1500P, SV431RACK, SVA12M2NEUA, SVA12M5NA, USBDVI4N1A10, USBDVI4N1A6, USBVGA4N1A10, USBVGA4N1A6
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
1 x VGA HD-15 , 1 x DVI-D , 4 x USB 2.0 Type A , 2 x audio mini-jack , 4 x VGA HD-15 , 4 x DVI-D , 4 x audio mini-jack , 4 x USB 2.0 Type B
External power adapter
FCC, RoHS
22 cm
13 cm
6 cm
1.2 kg
Limited warranty - 3 years
6LCZ StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £269.04
6LCZ StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £277.79
6LCZ StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £197.20
6LCZ StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £166.96
6LCZ StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
6LCZ StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £25.12
6LCZ StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.94
6LCZ StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.82
6LCZ StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.59
6LCZ StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.74
6LCZ StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.39
6LCZ StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £141.16
6LCZ StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £204.94
6LCZ StarTech.com 2-port Dual VGA KVM Switch In Stock £162.42
6LCZ StarTech.com 4-port Dual VGA KVM Switch In Stock £176.91
6LCZ StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
6LCZ StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
6LCZ StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £554.15
Ports: 4
Connectivity: KVM
