StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
Quicklinx: 76RDWS00 Mfr#: VS421DP
Switch between four DisplayPort sources on one DisplayPort MonitorThe VS421DP 4-port DisplayPort Switch offers superb multi-source control for demanding high-resolution display applications that require true high definition capability.
Supporting a native display resolution of 2560x1600 and 7.1 channels of audio (when connected to supporting displays and sources), this simple, yet comprehensive DisplayPort A/V Switch features both push-button and infrared remote control and offers a compact form factor design.
The VS421DP delivers a reliable solution for switching between multiple DisplayPort audio/video sources.
StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
DisplayPort
Ports
4 x DisplayPort
6.5 cm x 13.1 cm x 2.6 cm
0.5 kg
P/N: DISPL1M, DISPL2M, DISPL3M, DISPL50CM, DISPL5M, DISPLPORT1L, DISPLPORT20L, DISPLPORT30L
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
4 x DisplayPort
Status Indicators
Port status, power
4 x DisplayPort , 1 x DisplayPort
External power adapter
Wireless remote control
FCC, RoHS
6.5 cm
13.1 cm
2.6 cm
0.5 kg
0 - 80%
