Switch between four DisplayPort sources on one DisplayPort MonitorThe VS421DP 4-port DisplayPort Switch offers superb multi-source control for demanding high-resolution display applications that require true high definition capability.
Supporting a native display resolution of 2560x1600 and 7.1 channels of audio (when connected to supporting displays and sources), this simple, yet comprehensive DisplayPort A/V Switch features both push-button and infrared remote control and offers a compact form factor design.
The VS421DP delivers a reliable solution for switching between multiple DisplayPort audio/video sources.
- StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- DisplayPort
- Ports
- 4 x DisplayPort
- 6.5 cm x 13.1 cm x 2.6 cm
- 0.5 kg
- 2-year warranty
- Designed For
- P/N: DISPL1M, DISPL2M, DISPL3M, DISPL50CM, DISPL5M, DISPLPORT1L, DISPLPORT20L, DISPLPORT30L
- Enclosure Type
- Desktop
- Subtype
- DisplayPort
- Ports
- 4 x DisplayPort
- Status Indicators
- Port status, power
- 4 x DisplayPort , 1 x DisplayPort
- Power Device
- External power adapter
- Included Accessories
- Wireless remote control
- FCC, RoHS
- 6.5 cm
- 13.1 cm
- 2.6 cm
- 0.5 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
