StarTech.com 4 Bay SSD/HDD Docking Station
Quicklinx: DY8LWS00 Mfr#: SDOCK4U313
Type: Storage enclosure
HD Size: 2.5 / 3.5 shared
Power Supply: [N/A]
Hurry, only 1 left in stock!
£144.99 ex VAT
£173.98 inc VAT
Express delivery Order within the next 6 hours for delivery tomorrow
Gain quick access to up to four SSDs/HDDs simultaneously, while also being able to swap drives in and out as needed. This 4-bay SATA HDD docking station lets you access up to four solid-state drives or hard drives simultaneously over USB 3.1 (10Gbps), and hot swap drives with ease. Ideal for IT professionals, the docking station provides large data capacity and fast file transfers, helping you manage your workflow more efficiently.
When you're managing a large number of drives, the HDD/SSD docking station saves you time. Quickly dock and swap your drives for disk imaging, data recovery from failing drives, data backups, or other tasks.
The hard drive docking station also has SMART support, for accessing important drive information such as hours in use, number of power cycles, and disk health.
With USB 3.1 Gen 2, the HDD docking station lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The hard drive docking station includes a USB Type-C cable, for connecting to USB-C equipped laptops and devices, and a USB Type-A cable, for backward compatibility with your existing USB 3.0, 2.0 and 1.x devices.
The docking station also works with 2.5" and 3.5" IDE hard drives, mSATA drives and M.2 drives using a compatible StarTech.com adapter:
IDE hard drives: Use StarTech.com adapter SAT2IDEADP SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks.
mSATA drives: Use StarTech.com adapter SAT32MSAT257 mSATA SSD to 2.5in SATA Adapter Converter.
M.2 drives: Use StarTech.com adapter SAT32M225 M.2 NGFF SSD to 2.5in SATA Adapter Converter.
  • Save time accessing and managing your data
    When you're managing a large number of drives, the HDD/SSD docking station saves you time. Quickly dock and swap your drives for disk imaging, data recovery from failing drives, data backups, or other tasks. The hard drive docking station also has SMART support, for accessing important drive information such as hours in use, number of power cycles, and disk health.
  • Fast data transfers
  • Convenient compatibility
    The hard drive docking station includes a USB Type-C cable, for connecting to USB-C equipped laptops and devices, and a USB Type-A cable, for backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. The docking station also works with 2.5" and 3.5" IDE hard drives, mSATA drives and M.2 drives using a compatible StarTech.com adapter: IDE hard drives: Use StarTech.com adapter SAT2IDEADP SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks mSATA drives: Use StarTech.com adapter SAT32MSAT257 mSATA SSD to 2.5in SATA Adapter Converter M.2 drives: Use StarTech.com adapter SAT32M225 M.2 NGFF SSD to 2.5in SATA Adapter Converter The SDOCK4U313 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 4-Bay USB 3.1 to SATA Hard Drive Docking Station, 10Gbps USB Hard Drive Dock, External 2.53.5 SATA III (6Gbps) SSDHDD Docking Station, Hot-Swap Hard Drive Bay - Dual 60mm Fans, Top-Loading - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Expansion Bays
4 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5" / 3.5" shared
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
4
Product Material
Plastic
Power Source
USB bus
AC 120/230 V
17.1 cm x 29.1 cm x 8.7 cm
1 kg
2.5" / 3.5" shared
Host Bus
USB 3.1 (Gen 2)
Product Material
Plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
4
VIA Labs VL820 / VL715
Bays
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 24 pin USB-C
1 x USB-C 3.1 cable - external - 1 m , 1 x USB 3.1 cable - external - 1 m
Built-in 2 cooling fans, S.M.A.R.T. support, 4 LED indicators, tested with up to 10TB, TRIM support, 4Kn drive compatible
MTBF
30,000 hours
FCC, RoHS, UASP (USB Attached SCSI Protocol)
Power Source
USB bus
Power adapter
AC 120/230 V
78 Watt
17.1 cm
29.1 cm
8.7 cm
1 kg
Shipping Weight
2.4 kg
5 °C
35 °C
20 - 80%
DY8L StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.36
DY8L StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £20.67
DY8L StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.60
DY8L StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.53
DY8L StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £19.62
DY8L StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans In Stock £141.28
DY8L StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
DY8L StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.60
DY8L StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £86.89
DY8L StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.98
DY8L StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £56.18
DY8L StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.96
DY8L StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £15.19
DY8L StarTech.com 0.5m USB to USB-C Cable 10Gbps In Stock £9.03
Power Supply: [N/A]
Stock Status: While stocks last
Stock Status: Clearance
