Enable quick access to four 2.5"/3.5" SATA HDD over USB 3.0 or eSATA. The SATDOCK4U3E eSATA and USB 3.0 4-Bay SATA Hard Drive Docking Station is a convenient, time-saving storage solution for 2.5-inch and 3.5-inch SATA hard drives (HDD) and solid state drives (SSD) allowing for up to 4 SATA drives (tested with up to 4TB 3.5" and 1TB 2.5" drives per bay) to be conveniently and quickly connected to a host computer through a single connection.
The hard drive docking station features SuperSpeed USB 3.0 connectivity (also compatible with USB 2.0) with support for data transfer rates up to 5Gbps (10x faster than USB 2.0) or eSATA with Port Multiplier connectivity (up to 3Gbps), to provide fast connectivity to all 4 hard drives simultaneously.
The eSATA/USB 3.0 SATA hard drive docking station also features dual built-in, variable-speed 60mm fans that can be manually adjusted to keep each drive running cool, depending on the drives and operating environment, or turned off completely. Double the value of this hard drive docking station, using a SAT2IDEADP SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
- StarTech.com 4 Bay eSATA USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD - storage enclosure
- Storage enclosure
- Black
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- Supported Drives
- SATA-300
- Hard Drive
- No HDD
- OS Required
- Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4 - 10.7, Windows 8 (32/64 bits)
- Power
- AC 120/230 V
- 17.3 cm x 29.1 cm x 9.5 cm
- 1.05 kg
- 1-year warranty
- Designed For
- P/N: SAT2IDEADP, SVA12DN4NEUA
- Storage enclosure
- Enclosure Colour
- Black
Chassis
- 0
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-300
- CPU
- No CPU
Hard Drive
- No HDD
- Expansion Bays
- 4 (total) / 4 (free) x external - 2.5" / 3.5" shared
- 1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 3Gb/s - 7 pin external Serial ATA
- OS Required
- Cables Included
- 1 x eSATA cable , 1 x USB cable
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 17.3 cm
- 29.1 cm
- 9.5 cm
- 1.05 kg
- Limited warranty - 1 year
- Designed For
StarTech.com 3 ft Shielded External eSATA Cable M/M | In Stock | £8.88 |
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £10.50 |
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.36 |
StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter | In Stock | £6.36 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.60 |
