StarTech.com 4-Bay Dock for SSDs and HDDs
Quicklinx: C18LWS00 Mfr#: SDOCK4U33E
Get fast access to four 2.5"/3.5" SATA drives over USB 3.0 with UASP or eSATA. Dock and swap up to four drives from your laptop or desktop computer simultaneously, using a single eSATA or USB port. This 4-bay docking station gives you large data capacity and fast file transfers with support for SATA I, II and III (up to 6Gbps).
Access multiple drives with this quad-bay docking station. It saves you valuable time every day by giving you independent access to four 2.5" or 3.5" SATA hard drives or solid-state drives. Ideal for data recoveries, imaging or backups, it lets you access four drives at once, instead of connecting your drives one by one.
You can connect the docking station through either eSATA or USB. For fast performance and efficient data transfers when connected through eSATA, the docking station supports full SATA III transfer speeds - up to 6Gbps. For universal compatibility, the dock can be connected through USB 3.0 with transfer speeds up 5Gbps, plus it supports UASP for enhanced performance.
For IT technicians or business professionals who need to check files or test different drives, the dock lets you hot-swap your drives in and out as needed. Its top-loading, toaster-style design with drive ejection buttons make the dock easy to use while two silent cooling fans help to dissipate heat to maintain an optimum operating temperature.
With support for SATA I, II and III high-capacity drives (tested up to 6TB), this docking station is compatible with virtually any 2.5" and 3.5" SATA SSD or HDD drive.
The docking station also works with 2.5" and 3.5" IDE hard drives, mSATA drives and M.2 drives using a compatible StarTech.com adapter:
IDE hard drives: Use StarTech.com adapter SAT2IDEADP SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks.
mSATA drives: Use StarTech.com adapter SAT32MSAT257 mSATA SSD to 2.5in SATA Adapter Converter.
M.2 drives: Use StarTech.com adapter SAT32M225 M.2 NGFF SSD to 2.5in SATA Adapter Converter.
The quad-bay dock is OS independent, which ensures a quick and easy setup. It also features a compact design and small footprint that makes it easy to tuck into your workspace.
StarTech.com 4-Bay Docking Station for SSD & HDD - eSATA USB 3.0 to SATA - storage enclosure
Storage enclosure
0 (installed) / 4 (max)
Supported Drives
SATA-600
Hard Drive
No HDD
AC 120/230 V
17.12 cm x 29.05 cm x 8.73 cm
1.03 kg
Storage enclosure
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
Hard Drive
No HDD
Expansion Bays
4 (total) / 4 (free) x external - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA 6Gb/s - 7 pin external Serial ATA
Built-in 2 cooling fans, LED indicator
1 x eSATA cable , 1 x USB cable
MTBF
30,000 hours
External power adapter
AC 120/230 V
17.12 cm
29.05 cm
8.73 cm
1.03 kg
5 °C
35 °C
20 - 80%
C18L StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £29.00
C18L StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £50.03
