Hot swap up to four 3.5" SATA or SAS hard drives using three 5.25" bays. This 4-bay 3.5" SATA/SAS backplane, installed into three standard 5.25" front drive bays, makes it easy to swap 3.5" SATA or SAS drives in and out of your server or desktop computer. It features a trayless design that saves you installation time and enables you to insert or remove drives as needed. With its durable plastic and aluminum construction, it provides a cost-effective solution for drive maintenance and interchangeability of data between multiple systems.
This 4-bay backplane is ideal for IT professionals, such as system administrators or computer operators, for quickly swapping drives. With support for both SATA and SAS 3.5" drives, it saves valuable time in environments where storage drives need to be replaced or removed regularly, such as in server rooms and data centers.
The hot-swap backplane is a cost-effective solution for large deployments of system builds or upgrades, for organizations looking to stretch their IT budget.
The protective backplane is engineered with a plastic and aluminum design to safeguard your drives. Two built-in fans and ventilation help to optimize heat dissipation, to help protect your drives.
To maximize the speed and performance of your drives, the mobile rack supports SAS I and II and SATA I, II and III, providing data transfer speeds up to 6Gbps when paired with a compatible controller.
- StarTech.com 4 Bay 3.5" SATA SAS Backplane - 3 x 5.25in Bays - Trayless Mobile Rack - SATA Backplane - Removable Hard Drive Bay - HDD Rack (HSB43SATSASB) - storage mobile rack
- Storage mobile rack
- Expansion Bays
- 4 x hot-swap - 3.5"
- Compatible Bay
- 3 5.25"
- Supported Interface
- SATA-600
- Drive Connector
- 29 pin internal SAS (SFF-8482)
- Data indicator, power indicator, cooling fan
- Product Material
- Plastic, aluminium
- 2-year warranty
- Product Material
- SATA-600
Storage Controller
- Processor
- No CPU
- Bays
- 4 x SATA 6Gb/s - 29 pin internal SAS (SFF-8482)
- Connections
- 4 - 7 pin Serial ATA , 2 - 15 pin Serial ATA power
- Compatible Bay
- 3 x external 5.25"
- Included Accessories
- 8 x screws
- Cables Included
- 4 x Serial ATA cable
- Limited warranty - 2 years
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.16 |
StarTech.com 12in Latching SATA Cable | In Stock | £6.32 |
StarTech.com 18in Latching SATA Cable | In Stock | £5.24 |
StarTech.com 24in Latching SATA Cable | In Stock | £5.98 |
StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.78 |
StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane | In Stock | £43.92 |
StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter | In Stock | £5.01 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.34 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £5.12 |
StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - 4 Pin Molex to SATA | In Stock | £4.30 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.40 |
StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III | In Stock | £92.41 |
StarTech.com 5.25 to 3.5 Drive Hot Swap Bay | In Stock | £33.35 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.24 |
