Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC3MYL Cat 6 patch cable (3m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Reliable performance
The cable supports a tested frequency of up to 500 MHz, providing stable and high-speed data transmission suitable for various networking tasks. -
Enhanced durability
Constructed with a PVC jacket and gold-plated connectors, this cable is designed to withstand wear while maintaining excellent performance. -
Easy connectivity
The snagless design allows for quick connections, minimizing the risk of damage to adjacent ports during installation. -
Versatile compatibility
Equipped with male RJ-45 connectors on both ends, this patch cable is compatible with a wide array of devices, making it an ideal choice for home and office use. -
Industry compliant
This cable meets RoHS, ETL, and TIA/EIA-568-B standards, ensuring it adheres to necessary regulations for safe and effective use.
- StarTech.com 3m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC3MYL) - patch cable - 3 m - yellow
- Patch cable - CAT 6
- Technology
- Wires per Cable
- 4 wires
- Snagless
- Length
- 3 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 4 wires
- Pairs per Cable
- 8 pairs
- Plated Connector
- Gold
- Snagless
- Length
- 3 m
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
StarTech.com 3m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.22 |
StarTech.com 3m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £5.69 |
StarTech.com 3m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £5.75 |
StarTech.com 3m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £6.40 |
StarTech.com 3m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £8.80 |
StarTech.com 3m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £5.87 |
StarTech.com 3m Yellow Cat6 Patch Cable | In Stock | £5.80 |
StarTech.com 3m Green Cat6 Patch Cable | In Stock | £6.33 |
StarTech.com 3m Purple Cat6 Patch Cable | In Stock | £5.82 |
