StarTech.com 3m White Thunderbolt Cable - M/M
Quicklinx: 8SFMWS00 Mfr#: TBOLTMM3MW
Length: 3m
£52.70 ex VAT
£63.24 inc VAT
The Thunderbolt cables deliver the dependability you need to harness the speed and power of Thunderbolt technology and combine both data and video into a single high-performance cable.
You can find the perfect connection to suit any application, with the wide range of Thunderbolt cables. Compatible with Thunderbolt 1 (10 Gbps) and Thunderbolt 2 (20 Gbps) devices, the cables support bi-directional data transfer capability and power delivery for bus-powered devices. All of the Thunderbolt cables are constructed of highly durable materials and designed to the highest quality standards. Plus, the optical cables use optical fiber instead of copper so you don't need to worry about signal loss or EMI interference.
StarTech.com 3m White Thunderbolt Cable - M/M - Thunderbolt cable - 3 m
Thunderbolt cable
Double shielded
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
Thunderbolt 2
White
P/N: TB2DOCK4K2DP
Thunderbolt cable
Double shielded
Jacket Material
PVC
American Wire Gauge (AWG)
34
Plated Connector
Nickel
Length
3 m
White
120 g
Connector
Thunderbolt 2, FCC, RoHS
P/N: TB2DOCK4K2DP
8SFM StarTech.com 3m White Thunderbolt Cable - M/M In Stock £52.70
8SFM StarTech.com 1m White Thunderbolt Cable - M/M In Stock £30.64
8SFM StarTech.com 2m White Thunderbolt Cable - M/M In Stock £38.64
8SFM StarTech.com 0.5m White Thunderbolt Cable - M/M In Stock £27.01
Length: 3m
Price Range Ex VAT: 50 - 100
