This USB-C to DVI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DVI monitor or projector.
Clutter-free installation
This adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. -
Crystal-clear picture quality
The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver high video resolutions, providing support for your DVI monitors - great for multitasking on high-resolution DVI displays.
- StarTech.com 10ft (3m) USB C to DVI Cable, 1080p (Single Link) USB Type-C (DP Alt Mode HBR2) to DVI-Digital Video Adapter Cable, Thunderbolt 3 Compatible, Laptop to DVI Monitor/Display - USB-C Adapter Cable (CDP2DVI3MBNL) - external video adapter - VIA/VLI - VL100 / Parade - PS171 - black
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- Max Resolution
- 1920 x 1080
- DVI-D (dual link) (male connector)
- 2 cm 1 cm
- Length
- 3 m
- Enclosure Colour
- Black
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Bus Type
- USB-C
- Graphics Engine
- Max Resolution
- 1920 x 1080
- DisplayPort Alternate Mode
- FCC, RoHS
- 2 cm
- 1 cm
- Length
- 3 m
- 180 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 5 - 90% (non-condensing)
- Designed For
- P/N: TB4CDOCK
