Quicklinx: D0ZRWS00 Mfr#: USB2CC3M
Length: 3m
£9.26 ex VAT
£11.11 inc VAT
Charge and sync your USB Type-C mobile devices, over longer distances. This USB-C to USB-C cable makes it easy to charge and sync USB Type-C devices, such as the Samsung Galaxy S8, S8+, Nexus 6P, and 5X phones, using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
The 3-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel. Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
StarTech.com USB C to USB C Cable - 3m / 10 ft - USB Cable Male to Male - USB-C Cable - USB-C Charge Cable - USB Type C Cable - USB 2.0 (USB2CC3M) - USB-C cable - 3 m
USB-C cable
Shielded
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Thunderbolt 3 / USB 2.0
P/N: DKT30CHD
USB-C cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
23/28
Plated Connector
Nickel
Length
3 m
100 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3 / USB 2.0, RoHS, WEEE
P/N: DKT30CHD
D0ZR StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £5.49
D0ZR StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £6.04
D0ZR StarTech.com 1m Right Angle USB C Cable In Stock £7.86
D0ZR StarTech.com 3m USB 2.0 Type C Cable In Stock £9.26
Length: 3m
Price Range Ex VAT: 0 - 50
