Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B printer cable lets you connect your USB 2.0 peripheral devices, such as a printer, external drive or scanner to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
The longer cable lets you organize your desk to match your needs, enabling to connect your device up to 3 meters away from your computer.
- StarTech.com USB C to USB B Printer Cable - 10 ft / 3m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB2CB3M) - USB-C cable - 24 pin USB-C to USB Type B - 3 m
- USB-C cable
- Length
- 3 m
- Connector
- 24 pin USB-C - male - straight
- Connector (Second End)
- 4 pin USB Type B - male - straight
- Thunderbolt 3 / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
- USB-C cable
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/28
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- 68 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS
- Designed For
