Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB3ML 3-meter USB printer cable features one USB-A male connector and one left-angle USB-B male connector, providing a high-quality connection to USB 2.0 peripherals and enabling installation in narrow spaces.
As an alternative, StarTech.com also offers a 3m USB 2.0 A to Right Angle B Cable (USBAB3MR), which provides the same convenience as this left-angled cable, but allows you to connect to your USB device from the opposite direction.
- StarTech.com 3m USB 2.0 A to Left Angle B Cable Cord - 3 m USB Printer Cable - Left Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB3ML) - USB cable - USB Type B to USB - 3 m
- USB cable
- Technology
- Shielded
- Left-angled connector
- Length
- 3 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: ICUSB232D
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
- P/N: ICUSB232D
StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £14.48 |
StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £33.80 |
StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.13 |
StarTech.com 3M RIGHT ANGLE USB PRINTER | In Stock | £5.63 |
StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M | In Stock | £5.05 |
StarTech.com 2m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £5.02 |
StarTech.com 1m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £4.85 |
StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £4.68 |
