StarTech.com 3m Thunderbolt Cable - M/M
Quicklinx: 84P8WS00 Mfr#: TBOLTMM3M
The Thunderbolt cables deliver the dependability you need to harness the speed and power of Thunderbolt technology and combine both data and video into a single high-performance cable.
You can find the perfect connection to suit any application, with the wide range of Thunderbolt cables. Compatible with Thunderbolt 1 (10 Gbps) and Thunderbolt 2 (20 Gbps) devices, the cables support bi-directional data transfer capability and power delivery for bus-powered devices. All of the Thunderbolt cables are constructed of highly durable materials and designed to the highest quality standards. Plus, the optical cables use optical fiber instead of copper so you don't need to worry about signal loss or EMI interference.
StarTech.com 3m / 9.8ft Thunderbolt Cable - Compatible with Your Thunderbolt 1 and 2 / Mini DisplayPort Devices (TBOLTMM3M) - Thunderbolt cable - Mini DisplayPort to Mini DisplayPort - 3 m
Thunderbolt cable
Double shielded
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
Thunderbolt 2
P/N: TB2DOCK4K2DP
Thunderbolt cable
Double shielded
Jacket Material
PVC
American Wire Gauge (AWG)
34
Plated Connector
Nickel
Length
3 m
120 g
Connector
Thunderbolt 2, FCC, RoHS
P/N: TB2DOCK4K2DP
