Connect your 11 pin Samsung MHL Smartphone or Tablet to an MHL-enabled HDTV display. The MHD11PMM3M 3m Passive 11-pin Micro USB to HDMI cable lets you connect your MHL-enabled Samsung smartphone (S3, S4, S5, Note 2, Note 3) or tablet (Galaxy Tab Pro 8.4 and 10.1) to your MHL-enabled HDTV display, monitor, or projector.
This durable cable offers a simple plug-and-play solution for viewing content (e.g. photos, audio and video) from your Samsung mobile device on a large display, and home entertainment system.
Delivering on both quality and convenience, this 11-pin MHL cable supports 1080p video resolution and 7.1 channel digital audio output while simultaneously charging your mobile device when in MHL mode and while connected to your MHL-enabled display.
As this is a passive cable, your mobile device as well as your HDTV display, monitor, or projector, etc. must be MHL-enabled. Please refer to your devices owner's manual and/or visit the MHL consortium website for a list of MHL Enabled Products. This product will not work with devices that have a 5 pin MHL connector, such as the Samsung S2.
- StarTech.com 3m Passive 11 Pin Micro USB to HDMI MHL Cable for Samsung - video / audio cable - MHL / HDMI - 3 m
- Cable
- Video / audio cable - MHL / HDMI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/30
- Length
- 3 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- 11 pin Micro-USB (MHL) - male
- Limited lifetime warranty
- Cable Type
- Interface Supported
- MHL / HDMI
- Technology
- Shielded
- 24/30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 3 m
- Plated Connector
- Nickel
- Recommended Use
- Mobile phone
- Black
- Connector
- 19 pin HDMI Type A - male
- Plug and Play, RoHS, CEC
- Limited warranty - lifetime
