StarTech.com 3m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9F5WWS00 Mfr#: N6PATC3MOR
Length: 3m
Colour: Orange
More than 50 in stock
£3.50 ex VAT
£4.20 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC3MOR Cat 6 Patch Cable (3m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable orange PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 3m Orange Cat6 / Cat 6 Snagless Patch Cable - patch cable - 3 m - orange
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
3 m
Orange
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
9F5W StarTech.com 3m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.50
9F5W StarTech.com 3m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.50
9F5W StarTech.com 3m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £1.94
9F5W StarTech.com 3m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.50
9F5W StarTech.com 3m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.50
9F5W StarTech.com 3m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.50
Length: 3m
Colour: Orange
Price Range Ex VAT: 0 - 50
