Connect fiber network devices for high-speed transfers with LSZH rated cable. The FIBSTSC3 3-meter (10ft) Multimode 62.5/125 Duplex Fiber Patch Cable is terminated with one ST (male) connector and one SC(male) connector, to provide the necessary connection between fiber networking devices for high-speed, long distance networks.
This ST-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
To ensure optimum performance, the multimode fiber duplex cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
The ST-SC Multimode Fiber Patch cable is guaranteed to provide long-lasting dependability, and top quality performance.
- StarTech.com 3m Fiber Optic Cable - Multimode Duplex 62.5/125 - LSZH - ST/SC - OM1 - ST to SC Fiber Patch Cable (FIBSTSC3) - network cable - 3 m
- Network cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 3 m
- Core / Cladding Diameter
- 62.5 / 125 micron
- Connector
- 2 x SC multi-mode - male
- Connector (Second End)
- 2 x ST multi-mode - male
- Limited lifetime warranty
- Designed For
- P/N: US100A20FXSC, US100A20SFP, US1GA30SFP, US1GA30SXSC, US1GC30SFP
- Network Cable Type
- Network cable
- Technology
- Multimode
- 62.5 / 125 micron
- Length
- 3 m
- Connector
- Designed For
