Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCSC3 3m LSZH LC to SC Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
- StarTech.com 3m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/SC - OM2 - LC to SC Fiber Patch Cable - network cable - 3 m
- Network cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 3 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- 2 x SC multi-mode - male
- Limited lifetime warranty
- Designed For
- P/N: US100A20FXSC, US1GA30SXSC
- Network Cable Type
- Network cable
- Technology
- Multimode
- 50 / 125 micron
- Length
- 3 m
- Connector
- Designed For
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - SC | In Stock | £15.87 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - SC | In Stock | £16.55 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - SC | In Stock | £18.76 |
