View your pictures or videos from your HDMI Mini-equipped camera or other mobile device up to 3m away from your DVI-D display. The HDCDVIMM3M 3m Mini HDMI to DVI-D Cable enables you to view your pictures and videos from your HDMI Mini-equipped camera or other mobile device (Tablet, laptop, etc.) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations, you can use the 10ft (3m) Slim 3.5mm Stereo Audio Cable (MU10MMS).
The HDCDVIMM3M is designed and constructed for maximum durability, to ensure dependable performance.
- StarTech.com 3m Mini HDMI to DVI-D Cable - M/M - 3 meter Mini HDMI to DVI Cable - 19 pin HDMI (C) Male to DVI-D Male - 1920x1200 Video (HDCDVIMM3M) - adapter cable - HDMI / DVI - 3 m
- Cable
- Adapter cable - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 3 m
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- Mini HDMI - male
- Moulded
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 3 m
- Plated Connector
- Gold
- Moulded
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 19 pin mini HDMI Type C - male
- RoHS
- Limited warranty - lifetime
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.85 |
StarTech.com 2m Mini HDMI to DVI-D Cable - M/M | In Stock | £13.02 |
StarTech.com 1m Mini HDMI to DVI-D Cable - M/M | In Stock | £11.17 |
