View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 3m away from your DVI-D display. The HDDDVIMM3M 3m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 10ft (3m) Slim 3.5mm Stereo Audio Cable (MU10MMS).
The HDDDVIMM3M is designed and constructed for maximum durability, to ensure dependable performance.
- StarTech.com 3m Micro HDMI to DVI-D Cable - M/M - video cable - HDMI / DVI - 3 m
- Cable
- Video cable - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 3 m
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- Micro HDMI - male
- Moulded, strain relief
- Limited lifetime warranty
- Cable Type
- Video cable
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 3 m
- Plated Connector
- Gold
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 19 pin micro HDMI Type D - male
- RoHS
- Limited warranty - lifetime
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.52 |
StarTech.com 2m Micro HDMI to DVI-D Cable - M/M | In Stock | £10.94 |
StarTech.com 1m Micro HDMI to DVI-D Cable - M/M | In Stock | £10.02 |
StarTech.com 3m Micro HDMI to DVI-D Cable - M/M | In Stock | £13.85 |
