StarTech.com 3m Micro HDMI to DVI-D Cable - M/M
Quicklinx: 95F9WS00 Mfr#: HDDDVIMM3M
Length: 3m
£13.85 ex VAT
£16.62 inc VAT
View your pictures or videos from your HDMI Micro-equipped Smartphone or other mobile device up to 3m away from your DVI-D display. The HDDDVIMM3M 3m Micro HDMI to DVI-D Cable enables you to view your presentations, videos and pictures saved on your HDMI Micro-equipped mobile devices (Tablet, Smartphone) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 10ft (3m) Slim 3.5mm Stereo Audio Cable (MU10MMS).
The HDDDVIMM3M is designed and constructed for maximum durability, to ensure dependable performance.
StarTech.com 3m Micro HDMI to DVI-D Cable - M/M - video cable - HDMI / DVI - 3 m
Cable
Video cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
30
Length
3 m
Connector
DVI-D - male
Connector (Second End)
Micro HDMI - male
Moulded, strain relief
Cable Type
Video cable
Interface Supported
HDMI / DVI
Shielded
30
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Gold
Connector
18+1 pin digital DVI (Single-Link) - male
19 pin micro HDMI Type D - male
RoHS
Limited warranty - lifetime
95F9 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.52
95F9 StarTech.com 2m Micro HDMI to DVI-D Cable - M/M In Stock £10.94
95F9 StarTech.com 1m Micro HDMI to DVI-D Cable - M/M In Stock £10.02
95F9 StarTech.com 3m Micro HDMI to DVI-D Cable - M/M In Stock £13.85
Length: 3m
Price Range Ex VAT: 0 - 50
