Extend the connection distance between your DVI-D digital devices by 3 meters. The DVIDDMF3M 3m DVI-D Dual Link Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 3-meters.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
- StarTech.com 3m DVID Dual Link Monitor Extension Cable M/F - DVI extension cable - 3 m
- DVI extension cable - dual link
- Thumbscrews, ferrite bead
- Length
- 3 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - female
- RoHS
- Black
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- Connector
- 24+1 pin digital DVI - male
- 24+1 pin digital DVI - female
- RoHS
