StarTech.com 3m Dock Connector to USB Cable for ASUS Transformer Pad and Eee Pad Transformer Slider
Quicklinx: 8T5BWS00 Mfr#: USB2ASDC3M
Length: 3m
Select:
23 in stock
£8.21 ex VAT
£9.85 inc VAT
Charge your ASUS Transformer/Slider Tablet up to 3m distance from your power source. The USB2ASDC3M 3m ASUS Transformer USB Cable features one USB Type 'A' male connector and one (40-pin) ASUS male connector, delivering a simple way to connect your ASUS Eee Pad Transformer (TF101, Prime, etc.), ASUS Transformer Pad (Infinity, etc.) or ASUS Eee Pad Slider to a USB-capable computer.
This 3-meter long USB cable for ASUS tablets is twice as long as the standard supplied cable, and allows you to connect your ASUS Pad at further distances from your PC, or Mac Computer for data transfers or from an available power source for charging.
For convenience, this versatile ASUS tablet cable can be connected to a computer USB port for data transfers while you are working. Or you can connect the cable to the USB power adapter which was supplied with your ASUS Pad, for simple charging from an available (wall) power outlet.
This ASUS Transformer USB Cable is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced data / charging cables.
StarTech.com 3m Dock Connector to USB Cable ASUS Transformer Pad / Eee Pad - charging / data cable - 3 m
Cable
Charging / data cable
Double shielded
American Wire Gauge (AWG)
30/32
Length
3 m
Connector
ASUS 40-pin Dock Connector - male
Connector (Second End)
USB - male
ASUS Transformer Pad TF300T, TF300TG, TF300TL
Cable Type
Double shielded
30/32
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Nickel
Recommended Use
Tablet
Connector
4 pin USB Type A - male
RoHS
Limited warranty - lifetime
8T5B StarTech.com 3m Dock Connector to USB Cable for ASUS Transformer Pad and Eee Pad Transformer Slider In Stock £8.21
Length: 3m
Price Range Ex VAT: 0 - 50
