StarTech.com 3m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable
Quicklinx: 8JFNWS00 Mfr#: SFPCMM3M
Length: 3m
31 in stock
£53.85 ex VAT
£64.62 inc VAT
Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU3M cable. The SFPCMM3M Cisco Compatible 3m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU3M cable.
StarTech.com 3m 10G SFP+ to SFP+ Direct Attach Cable for Cisco SFP-H10GB-CU3M - 10GbE SFP+ Copper DAC 10Gbps Passive Twinax - direct attach cable - 3 m
Direct attach cable
Twinaxial
Latching connectors
Length
3 m
Connector
SFP+
Connector (Second End)
SFP+
P/N: ET10GSFP, PEX10000SFPI, PEX10GSFP4I, PEX20000SFPI
Network Cable Type
Direct attach cable
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Latching connectors
Length
3 m
Connector
SFP+
SFP+
RoHS, MSA
70 °C
Length: 3m
Stock Status: In stock
