StarTech.com 3m Black SuperSpeed USB 3.0 Cable - Right Angle A to B - M/M
Quicklinx: 8SFRWS00 Mfr#: USB3SAB3MRA
Length: 3m
Select:
10 in stock
£7.23 ex VAT
£8.67 inc VAT
Connect USB 3.0 devices, even in hard to reach areas and tight spaces. The USB3SAB3MRA 3m Black USB 3.0 A to B cable features a right-angled USB ''A'' male connector, enabling you to connect your USB 3.0 Type ''B'' peripherals to your PC, laptop, or server, even in hard to reach areas and tight spaces.
The right-angled USB ''A'' connector positions the cable nearly flush against a wall or other surface, and eliminates the space typically required to accommodate a ''straight'' connection from the cable into the USB port.
Harnessing the full capabilities of the SuperSpeed USB 3.0 standard when used with a USB 3.0 host and device, the 3m cable offers a bandwidth of 5Gbps.
Plus, this right angle USB 3.0 cable also features high quality Shielded Twisted Pair (STP) construction, which helps prevent electro-magnetic interference and ensure reliable data communication.
StarTech.com 3m Black SuperSpeed USB 3.0 Cable - Right Angle A to B - M/M - USB cable - 3 m
USB cable
Shielded twisted pair (STP)
Molded, right-angled connector
Length
3 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
3 m
Connector
USB 3.0, RoHS
Length: 3m
Price Range Ex VAT: 0 - 50
