StarTech.com 3m (10 ft) Long Apple 30-pin Dock Connector to USB Cable with Stepped Connector
Quicklinx: 85FKWS00 Mfr#: USB2ADC3M
Length: 3m
Hurry, only 3 left in stock!
£18.36 ex VAT
£22.03 inc VAT
Charge and sync your iPhone, iPod or iPad at greater distances (up to 3m) with no loss of charge time, even while inside a protective case. The USB2ADC3M Apple (30-pin) Dock Connector to USB cable for iPhone, iPod and iPad (3m) connects your iOS-enabled mobile digital devices to your computer and features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge.
This USB to iPhone cable features heavy gauge (20 AWG) wire, which enables convenient syncing and charging of your Apple devices up to 3 meters away from your computer or wall outlet, overcoming distance restrictions while delivering full charging power to your devices with no loss of charge time.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 3m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 3m (10 ft) Long Apple 30-pin Dock Connector to USB Cable for iPhone iPod iPad with Stepped Connector (USB2ADC3M) - charging / data adapter - 3 m
Cable
Charging / data adapter
American Wire Gauge (AWG)
20
Length
3 m
White
Connector
Apple Dock - male
Connector (Second End)
USB - male
Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Cable Type
20
Jacket Material
PVC
Length
3 m
Recommended Use
Portable player
White
Connector
Apple Dock connector - male
4 pin USB Type A - male
RoHS, MFI
Limited warranty - lifetime
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPhone 3G, 3GS, 4, 4S , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G) , Apple iPod touch (1G, 2G, 3G, 4G)
85FK StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to USB Cable with Stepped Connector In Stock £9.13
85FK StarTech.com 3m (10 ft) Long Apple 30-pin Dock Connector to USB Cable with Stepped Connector In Stock £18.36
Length: 3m
Price Range Ex VAT: 0 - 50
