Eliminate clutter by connecting your PC directly to an HDMI display using this short cable. This 3-foot DisplayPort to HDMI adapter cable lets you connect your DisplayPort equipped Ultrabook, laptop or desktop computer to an HDMI television, monitor or projector with no additional adapters or cables required. The passive adapter supports video resolutions up to Ultra HD 4K.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting DisplayPort to HDMI. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this DP to HDMI adapter connects directly from your DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling.
At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, StarTech.com also offers a 6 ft DP to HDMI cable (DP2HDMM2MB), enabling you to choose the right cable length for your custom installation needs.
Astonishing picture quality
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting DisplayPort to HDMI. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video. -
Hassle-free setup
For the simplest and most discreet installation, this DP to HDMI adapter connects directly from your DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling. -
Clutter-free installation
At 3ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, we also offer a 6 ft DP to HDMI cable (DP2HDMM2MB), enabling you to choose the right cable length for your custom installation needs. The DP2HDMM1MB is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com 3 ft (1 m) DisplayPort to HDMI Adapter Cable - 4K DisplayPort to HDMI Converter Cable - Computer Monitor Cable (DP2HDMM1MB) - adapter cable - DisplayPort / HDMI - 1 m
- Cable
- Adapter cable - DisplayPort / HDMI
- Length
- 1 m
- Black
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - male
- DisplayPort 1.2
- 4K support
- 3-year warranty
- Designed For
- P/N: TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Cable Type
- Adapter cable 4K support
- Interface Supported
- DisplayPort 1.2
- Length
- 1 m
- HDCP compliant, DPCP compliant
- Black
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - male
- FCC, RoHS
- Limited warranty - 3 years
- Designed For
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.84 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £11.50 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.86 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £15.98 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £21.47 |
StarTech.com 3ft DP to HDMI cable - 4K | In Stock | £14.50 |
StarTech.com 6ft mDP to HDMI cable - 4K | In Stock | £15.81 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £15.82 |
StarTech.com 3ft mDP to HDMI cable - 4K | In Stock | £14.50 |
StarTech.com 5m DisplayPort to HDMI Cable - 4K | In Stock | £22.64 |
StarTech.com 3m DisplayPort to HDMI Cable - 4K | In Stock | £21.01 |
StarTech.com DisplayPort to HDMI Cable | In Stock | £41.98 |
