Connect a high-powered server to a power distribution unit. This C19 to C20 power cord from StarTech.com features 14 AWG wire that's suitable for high power connections, making it perfect for server application and connecting to a Power Distribution Unit (PDU).
Plus, you can use the cable to extend the reach of your existing power cord by 3 feet, which gives you the extra distance you need to place your devices according to your server room configuration.
- StarTech.com 3 ft Heavy Duty 14 AWG Computer Power Cord - C19 to C20 - 14 AWG Power Cable - IEC 320 C19 to IEC 320 C20 Extension Cord - power cable - IEC 60320 C19 to IEC 60320 C20 - 90 cm
- Power cable
- Service Junior Thermoplastic (SJT) jacket
- Length
- 90 cm
- Connector
- Power IEC 60320 C19
- Connector (Second End)
- Power IEC 60320 C20
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 14
- Rated Voltage
- AC 250 V
- Length
- 90 cm
- Black
- Connector
- RoHS
