StarTech.com 3ft C19 to C20 Power Cord
Quicklinx: B680WS00 Mfr#: PXTC19C20143
Connect a high-powered server to a power distribution unit. This C19 to C20 power cord from StarTech.com features 14 AWG wire that's suitable for high power connections, making it perfect for server application and connecting to a Power Distribution Unit (PDU).
Plus, you can use the cable to extend the reach of your existing power cord by 3 feet, which gives you the extra distance you need to place your devices according to your server room configuration.
StarTech.com 3 ft Heavy Duty 14 AWG Computer Power Cord - C19 to C20 - 14 AWG Power Cable - IEC 320 C19 to IEC 320 C20 Extension Cord - power cable - IEC 60320 C19 to IEC 60320 C20 - 90 cm
Power cable
Service Junior Thermoplastic (SJT) jacket
Length
90 cm
Connector
Power IEC 60320 C19
Connector (Second End)
Power IEC 60320 C20
Rated Voltage
AC 250 V
Power cable
American Wire Gauge (AWG)
14
Rated Voltage
AC 250 V
Length
90 cm
Connector
Power IEC 60320 C19
Power IEC 60320 C20
RoHS
