Connect a high-powered server to a power distribution unit. This C14-to-C19 power cord features 14 AWG wire that's suitable for high-power connections, making it perfect for high-end server equipment such as routers, switches, Power Distribution Units (PDU), etc.
Plus, you can use the cable to extend the reach of your existing power cord by 3 feet, which gives you the extra distance you need to place your devices according to your server room configuration.
- StarTech.com 3 ft Heavy Duty 14 AWG Computer Power Cord - C14 to C19 - power cable - 90 cm
- Power cable
- Service Junior Thermoplastic (SJT) jacket
- Length
- 90 cm
- Connector
- Power IEC 60320 C19
- Connector (Second End)
- Power IEC 60320 C14
- Rated Voltage
- AC 110 V
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 14
- Rated Voltage
- AC 110 V
- Length
- 90 cm
- Black
- Connector
- UL, RoHS
