StarTech.com 3ft/1m Secure Charging Cable - USB-A to Micro
Quicklinx: GB6KWS00 Mfr#: USBSCHAU1M
Length: 100cm
18 In Stock
£5.87 ex VAT
£7.04 inc VAT
Data Blocker USB Charger USB-A to USB Micro-B 5V, 2.4A (12W) 2-Year Warranty. This USB-A to USB micro-B Data Blocker cable lets you securely charge your device by establishing a power-only connection between your device and the host system or power source. Equipped with no-data USB-A male connector with a unique cut-away design, this secure cable prevents malware attacks and data thefts, and provides a safe way to charge your mobile devices.
Power-Only USB-A to micro-B Cable
The USB-A port of this cable does not have physical data pins, resulting in a cable with physical barrier for data transmission. This cable allows you to charge your mobile devices from a laptop or desktop computer while eliminating any possibility of
Data theft from the host computer
Data corruption on the host computer
Infection from spyware/malware or viruses being transmitted from the mobile device to the host network
Handy Cable for Everyday Use
Portable 3ft (1m) long cable fits into your pocket or laptop bag, and lets you safely charge your smart phones, tablets, headphones, cameras, etc. in public charging stations/ports in airports, hotels and restaurants. Absence of data lines also makes these cables safe to use in government, defense, corporate and educational environments, where connecting your mobile device may be prohibited.
Smart, Powerful and Versatile Cable
High throughput cable with 22AWG (0.34 sqmm) power lines delivers 5V up to 2.4A (12W max.). Smart on-board chip identifies the device's power requirements and adjusts the output accordingly. Industry standard connectors let you charge all your USB micro-B enabled devices from all USB-A power outlets - from host computers to wall chargers.
Robust and Reliable Construction
The cable's jacket and connector molds are made from tough TPE plastic that offers better flexibility and high resilience to fraying and scratches, making it ideal for everyday rough use. Aluminium-Mylar foil with Braiding provides noise-free DC power to your device.
Comprehensive Product Testing & Expert Technical Support
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have a broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales.
USBSCHAU1M is backed by a StarTech.com 2-year warranty.
  • Secure charging cable
    Cable to charge smart phones, tablets, headphones, cameras anywhere, ideal for high-security use in public, corporate, defence & educational environments
  • Robust and reliable construction
StarTech.com 3ft (1m) Secure Charging Cable, USB-A to Micro USB Data Blocker Charge-Only Cable, Power-Only Charger Cable for Phone/Tablet, Data Blocking USB Protector Adapter Cable, TPE - 5V at 2.4A (12W max) (USBSCHAU1M) - USB cable - USB (power only) to Micro-USB Type B (power only) - 100 cm
USB cable
Molded, passive cable, copper conductors
Length
100 cm
Connector
4 pin USB Type A (power only) - male
Connector (Second End)
5 pin Micro-USB Type B (power only) - male
Rated Voltage
5 V
Rated Current
2.4 A
USB cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22
Rated Voltage
5 V
Rated Current
2.4 A
Plated Connector
Nickel
Length
100 cm
Outside Diameter
3.1 mm
1.75 cm
0.98 cm
12.3 g
Connector
WEEE, RoHS 2011/65/EU, REACH 2006/1907
Shipping Width
12.5 cm
Shipping Depth
9 cm
Shipping Height
3 cm
Shipping Weight
22.3 g
Length: 100cm
