StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable
Quicklinx: 82HJWS00 Mfr#: SATA36RA1
Length: 91.4cm
19 in stock
£3.97 ex VAT
£4.76 inc VAT
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA36RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 36-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable - SATA cable - 91.4 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Right-angled connector
Length
91.4 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: PEXSATA24E, SATABAY5BK, SATATRAYBK, SATABAY3BK, SATABAY4BK, PCISATA4R1
Storage Cable Type
SATA cable
Interface Speed
Length
91.4 cm
Red
Connector
RoHS
StarTech.com 2 Port eSATA + 4 Port SATA PCI Express x4 SATA Controller Adapter Card, 3 Drive 3.5in SATA Hot Swap Hard Drive Backplane with RAID, 4 Drive 3.5in Hot Swap SATA Mobile Rack Backplane, 4 Port PCI SATA RAID Controller Adapter Card, Extra 3.5in Hot Swap Hard Drive Tray for SATA and SAS Backplanes
82HJ StarTech.com 36in SATA Serial ATA Cable In Stock £3.15
82HJ StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable In Stock £3.97
Length: 91.4cm
Price Range Ex VAT: 0 - 50
