StarTech.com 35m USB 2.0 Active Extension Cable - M/F
Quicklinx: 89CYWS00 Mfr#: USB2AAEXT35M
Extend the distance between a computer and a USB 2.0 device by 35 meters. The USB2AAEXT35M 35-meter Active USB 2.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 2.0 devices of up to 35-meters (115-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable.
The USB2AAEXT35M extension cable (USB Extender) supports transfer rates of up to 480 Mbps.
StarTech.com 35m USB 2.0 Active Extension Cable - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 115 ft - active - black - USB2AAEXT35M - USB extension cable - USB to USB - 35 m
USB extension cable
Shielded
Active cable (signal regeneration)
Length
35 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: SVA5H2NEUA, UUSBOTG
USB extension cable
Shielded
Plated Connector
Nickel
Length
35 m
Connector
USB / USB 2.0, FCC, RoHS
89CY StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
89CY StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
89CY StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £79.93
89CY StarTech.com 15m USB 2.0 Active Extension Cable - M/F In Stock £61.53
89CY StarTech.com DC Power Adapter - 5V, 2A In Stock £9.91
