StarTech.com 35 ft Purple Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 7B6JWS00 Mfr#: N6PATCH35PL
Length: 10.7m
Colour: Purple
30 in stock
£10.55 ex VAT
£12.66 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH35PL Cat 6 Patch Cable (35 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable purple PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 35 ft Purple Cat6 / Cat 6 Snagless Patch Cable 35ft - patch cable - 10.7 m - purple
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless
Length
10.7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Purple
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Snagless
Length
10.7 m
Purple
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 650 MHz
7B6J StarTech.com 25ft Purple Cat6 Patch Cable In Stock £7.22
7B6J StarTech.com 35 ft Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.07
7B6J StarTech.com 35 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.07
7B6J StarTech.com 35 ft Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.07
7B6J StarTech.com 35 ft Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.64
7B6J StarTech.com 35 ft Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.07
7B6J StarTech.com 35 ft Purple Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £10.55
Length: 10.7m
Colour: Purple
Price Range Ex VAT: 0 - 50
