StarTech.com 35 ft Coax High Resolution VGA Monitor Extension Cable -  HD15 M/F
Quicklinx: 6BB5WS00 Mfr#: MXT101HQ35
Length: 10.7m
Hurry, only 1 left in stock!
£23.83 ex VAT
£28.59 inc VAT
This 35ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 35 ftCoax High-Resolution VGA Monitor extension Cable M/F - VGA extension cable - 10.7 m
VGA extension cable
Coaxial
Molded
Length
10.7 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
VGA extension cable
Coaxial
Molded
Length
10.7 m
Connector
15 pin HD D-Sub (HD-15) - female
Length: 10.7m
Price Range Ex VAT: 0 - 50
