StarTech.com 35 ft Coax High Resolution Monitor VGA Cable -  HD15 M/M
Quicklinx: 6BBBWS00 Mfr#: MXT101MMHQ35
Connect your VGA monitor with the highest quality connection available. The MXT101MMHQ35 High Resolution VGA Cable (35ft) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 35 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 10.7 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
10.7 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
P/N: CDP2VGA, CDP2VGAFC, DVI2VGAE, DVIVGAMF, DVIVGAMFBK, HD2VGAE2, HD2VGAMICRO, RACKCONV1701, VGAPLATE
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
10.7 m
Connector
RoHS
