StarTech.com 30m Coax High Resolution Monitor VGA Video Cable - HD15 M/M
Quicklinx: 87NJWS00 Mfr#: MXTMMHQ30M
Length: 30m
10 in stock
£58.11 ex VAT
£69.73 inc VAT
Connect your VGA monitor with the highest quality connection available. The MXTMMHQ30M High Resolution VGA Cable (30-meter) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 30m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 30 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
30 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
30 m
Connector
RoHS
87NJ StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
87NJ StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £23.03
87NJ StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £36.43
87NJ StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £49.74
87NJ StarTech.com 25m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £52.69
87NJ StarTech.com 1m Monitor VGA Cable In Stock £5.11
87NJ StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cable - HD15 M/M In Stock £5.22
Length: 30m
Price Range Ex VAT: 50 - 100
