Create multiple temporary guest WiFi accounts for secure wireless access at the touch of a button. The R300WN22GAGB Wireless-N Guest WiFi Access Point (WAP) lets you create multiple temporary guest WiFi accounts, for secure wireless network access at the touch of a button.
The guest access point offers simplicity for both the end-user and the IT professional implementing it, by integrating an LCD display and a "Get Key" button directly onto the device. When the button is pressed, the device will generate and display a temporary User ID and Security Key, based on your configured settings. From there, the user simply connects their device to the Guest wireless network and they are on the Internet.
The guest WiFi AP can be easily configured to use separate SSIDs and network segments for guests and employees, helping you provide fast network connectivity for your guests, while still protecting internal network resources and intranet sites.
Supporting wireless-N data rates up to 300 Mbps on the 2.4GHz frequency, the wireless AP is compatible with 802.11b/g/n standards and supports WPA and WPA2 authentication, for a secure connection. The WAP also offers an easy-to-use web interface which offers configuration options including multiple SSIDs, custom login / user agreement pages, bandwidth management and usage reporting.
- StarTech.com 300Mbps 2T2R Wireless-N Guest WiFi Access Point / Account Generator - 2.4GHz 802.11b/g/n - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Processor
- Ralink RT3052
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- 14.3 cm x 22.2 cm x 3.6 cm
- 400 g
- 2-year warranty
- 14.3 cm
- 22.2 cm
- 3.6 cm
- 400 g
- Enclosure Colour
- Black & silver
- Localisation
- United Kingdom
Processor / Memory / Storage
- Processors Installed
- Ralink RT3052
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- CSMA/CA
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 30 m
- Status Indicators
- Power, WAN, LAN, link/activity
- 2T2R MIMO technology
- Encryption Algorithm
- AES, TKIP, WPA
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- 5 x - RJ-45
- Cables Included
- 1 x network cable
- FCC, RoHS
- Power Device
- External power adapter
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 20 - 90% (non-condensing)
