Your basket is empty
StarTech.com 300Mbps 2T2R Wireless-N Guest WiFi Access Point / Account Generator 2.4GHz 802.11b/g/n
Quicklinx: 9YY8WS00 Mfr#: R300WN22GAGB
  • IEEE 802.11n
Create multiple temporary guest WiFi accounts for secure wireless access at the touch of a button. The R300WN22GAGB Wireless-N Guest WiFi Access Point (WAP) lets you create multiple temporary guest WiFi accounts, for secure wireless network access at the touch of a button.
The guest access point offers simplicity for both the end-user and the IT professional implementing it, by integrating an LCD display and a "Get Key" button directly onto the device. When the button is pressed, the device will generate and display a temporary User ID and Security Key, based on your configured settings. From there, the user simply connects their device to the Guest wireless network and they are on the Internet.
The guest WiFi AP can be easily configured to use separate SSIDs and network segments for guests and employees, helping you provide fast network connectivity for your guests, while still protecting internal network resources and intranet sites.
Supporting wireless-N data rates up to 300 Mbps on the 2.4GHz frequency, the wireless AP is compatible with 802.11b/g/n standards and supports WPA and WPA2 authentication, for a secure connection. The WAP also offers an easy-to-use web interface which offers configuration options including multiple SSIDs, custom login / user agreement pages, bandwidth management and usage reporting.
StarTech.com 300Mbps 2T2R Wireless-N Guest WiFi Access Point / Account Generator - 2.4GHz 802.11b/g/n - radio access point
Radio access point
External
United Kingdom
Ralink RT3052
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
14.3 cm x 22.2 cm x 3.6 cm
400 g
2 years warranty
Radio access point
14.3 cm
22.2 cm
3.6 cm
400 g
Enclosure Colour
Black & silver
United Kingdom
Processor / Memory / Storage
Processors Installed
Ralink RT3052
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz
Max Range Open Space
30 m
Status Indicators
Power, WAN, LAN, link/activity
2T2R MIMO technology
Encryption Algorithm
AES, TKIP, WPA
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
5 x - RJ-45
1 x network cable
FCC, RoHS
External power adapter
50 °C
20 - 90% (non-condensing)
9YY8 StarTech.com 75 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £20.75
9YY8 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £24.15
